est. 1/4 time
NinjaMax
WTF!
Oct 3, 2012
1,266
42
Severance, Colorado
My lift is coming off in the next week..soo..I'm now able to turn my dd into something I can play with a little at the track..my question is what kind of times are you guys seeing with these mods
Built trans
475/stock compounds
Fass 150
Studded
Kryptonite stg3 front end
60" trac bars
Stock bottom
Stock cp3
Stock injectors
Still have to decide on gears/rims/tires/lockers
Any advice on that's would be great:D
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Depends on the weight and what you run for tires. I have the exact same set up in my 07 classic cc/sb (but no studs) and it weighed 6850. I didn't have a huge tune in it but would run 12.7 at 107 everytime down the track. Drove with the same tune on the street.
custom8726
2,784
Upstate N.Y
Built trans
475/stock compounds
Fass 150
Studded
60" trac bars
Stock bottom
Stock cp3
Stock injectors
Weight depending, I would guess mid to high 12's with a decent launch. For the 1/4 a 31" A/T tire with 3.73 gears works well and I wouldnt waist your money on a front locker for the drag strip. If your talking rear locker I run a Grizzly and it works well for a DD weekend warrior truck IMO.. Although if I was doing a rear locker over again I would go with the ARB for a daily driver, The grizzly is hard on rear tires;)
5,850
get it to launch and assuming it holds somewhat decent rail, id say a mid to high 12 as well. i ran a 13.04 @ 105 on the same setup with 37s and 7500lbs with a 2800uS tune and rail dropping to 20-21k. switching to a 3200 dropped my times to 13.2.
Teabagger remembers these runs all so well when i beat him prior to his lift lol :D
Subman
Old Geezer
Jun 27, 2008
3,233
80
Do not put in a front locker!!! That is unless you like playing with the wall on a drag strip. :D You won't need it nor do you need a rear locker for that matter, you are not making enough power to mess with it.
Low366Dmax
Pin it to win it
Aug 23, 2013
185
NH
30 psi in tires all around leave at like 10psi and pray she holds rail a mid 12 @ 105-109 isn't put of the question
Sent from my iPhone
Andrew
Costly Obsessions
Aug 7, 2013
275
delaware
could you elaborate a little on why pls? my truck will have front an rear lockers for pulling just curious why it would casue that on the track?:baby:
Jakemax04
Jun 28, 2013
127
I run an average of 12.8's on stock turbo and at around 6500 lbs. I hope compounds could put me in low 12's
