What can be done if anything for repeated upshift/downshift on grades? I recently installed EFI Live so I could take advantage of the loss of a DPF. I am running 275/70R18 tires which are 33.25 dia. and the revs were put into the tunes (DSP5 switch).
In cruise control set at 70mph on a grade the trans will downshift then upshift then down again and so on all the way to the top. Yesterday on the same grade when it downshifted, I put it in manual mode 5 then upshifted to 6 thinking it would stay there. It downshfted by itself and it still said the trans was in 6! It would then do the same as before, down then up, down then up.
Any ideas? Should I have the TCM tune changed to spread out the 5 to 6 shifting?
