EPR Big Twins on the way!!!
Builtlngbd
Aug 24, 2009
392
Well I finally took the step and can't wait to see how hard she is gunna scream. Kinda nervous lol gunna take sone time to get use tithe new power!!!! Thanks Trent for all the help and stuff and answering all my questions soo far! Can't wait to get your kit!
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
That should move up the list a few more spots for sure:Ds480 over pbk:thumb:
Well not excatly on the way but being built :D , turbo's are S472/PBK , we are keeping it fairly street able but she should be over 1k on fuel :) , I am excited to build it Jared and think you will be real happy with it .
duramax hd
664
CT
That sounds like a nasty setup built by a sick builder. I look forward to seeing how this goes and good luck getting into the tens:coolspot:
HogAssWild
Nov 12, 2009
502
how much is the pbk alone and would it be pretty simple to put on my set up?
sorry for derail delete if its a problem
TrentNell
Jul 7, 2008
7,543
slc tuah
PBK is $2900.00 which to some seems high , right until you look at the price of a GT5541 :eek: ( awesome charger but $$ ) then it seems like a bargain considering it flow's with in 3lbs per minute of it, has a bigger main shaft, 360 thrust bearings, and spools as fast or faster. I would say that the minimum size turbo to flow it through (high pressure / top turbo) would be a 68-70 mm but ideally the bigger the charger the better the setup will flow , one day i will try it with a S366 and see what happens , but it would never work with a stock turbo .
Builtlngbd
Aug 24, 2009
392
Larry once I get them in i will take a trip over that way so we can do some testin:thumb:On how good they run haha
