I did some searching on this and I think I'm fine, but wanted to ask here before I call it good. This weekend I was towing about a 7500 pound box trailer that has ALOT of wind drag to it with the BURB running 60-65 into about a 15 MPH headwind. Outside temp was about 94-95 degrees and I had both airs blasting on high. The engine temps got up to about 200-205 on my guage which is the highest she has gotten so far on me. The fan clutch never kicked in, not even when I came to a redlight(engine temps would drop coming up to a redlight though). EGT's were holding around 650-675 post turbo, and boost was around 10 or so and it was FLAT land. Are these numbers pretty well normal? I know when I had the 6.5 210 was pretty much as hot as you wanted to keep it for any length of time, just not sure what is safe on a DURAMAX yet? I'm going to install a deflector in my bumper to help push more airflow through the stack as my grille opening is rather small compared to a NBS truck.
