Ls2 would be SWEET!
:woott:
Anything will be SWEET with the proper application of parts and attention, your opportunities are limitless in the platform you're delving into Corey!
The LS2 is the obvious choice for a lighter "entry level" block that offers significant displacement, although I wouldn't stroke it...
There will probably be some swapping necessary, like reluctor wheels, knock position sensors and some pins that need to be moved...etc
Your best bet is to find out what reluctor wheel your Yukon has and find a donor match
Most the LS2's had the 24x reluctor wheel, which is what I believe the LQ4 and the LY6 had...
Trans wise, you can bolt almost ANYTHING to an LS2 or any LS variant
What's in there now, an LQ4/4L65?
Whatever you do, make the swap worth while and use better than the factory castings that what comes for heads on the LQ4...
I've got an LS2 bare block
And a 4L70...
Some ported 243's with stainless oversized valves and a mild cam on a 366ci LS2 with full long tubes is a potent little engine combo... Good for 450 to the wheels and 12-14mpg
Lol
