Been having an issue with my 05 lly. Cranks fine, then after a few moments it will start shuttering like it’s about to die. It does it off and in for a minute then clears up. I put a scanner on and watched the injector rates and they are all within range. This morning it done it, but when I started down the road, it lost power and wouldn’t run over 35 at WOT. Turned around and came back left the truck running and hooked the scanner by up. Injector 1,6,4, and 7 showed exactly -7.0 the other 4 showed exactly 15. I turned it off as cranked it back up and it was still idling rough. Turned off and let sit for 10 minutes or so and it cranked fine. Idle and throttle response where back to normal, along with balance rates. It will still miss on occasion. Balance rates are back to normal. Any ideas?
