LB7: Engine overhaul kit?
1,836
Just need to find out what exactly is in this "Engine Overhaul Kit" that I found online, if it includes all gaskets for the entire top half of the engine, and how much it is.
This may be what Ive been looking for.
part number is 97729798
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Got a link? cost ?
Observer
Newbie Diesel-holic
Dec 30, 2009
15
Coeur d'Alene, Idaho
I happened to find an Ebay auction for it, and now am curious as to just what it includes. http://cgi.ebay.com/ebaymotors/ws/e...0595944045&viewitem=&sspagename=STRK:MEWAX:IT
Interesting ... I took the GM Part No. 97729798 listed in this auction, then went over to GMPartsDirect.com ... this is the result:
GM PART # 97729798
CATEGORY: Engine Cylinder Head Gasket
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $550.71
OUR PRICE: $326.46
The eBay auction listed above had a Buy It Now price of $499.99 without any guarantee that all the parts were included. I guess it pays to shop ... but it was nice that the GM Part Number was provided for this purpose. :D
KEVINL
1,431
Phoenix, AZ
Alot of that stuff is reusable might be cheaper to just buy what you need
I don't see any head gaskets or bearings
I spent less than $300 on everything I needed to do my heads including the head gaskets
1,836
GM PART # 97729798
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $550.71
OUR PRICE: $326.46
Thats exactly what I did. Why do you think Im asking whats in the kit? If head gaskets came with it, plus all the other topmotor gaskets, for that price, itd definitely be worth it.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Itried to buy that kit from parts direct last fall. its no longer a good # and they wont update on site. the newer kit is over $500.
ripmf666
15,123
14
47
Wentzville Mo
The head gaskets are not in any Gm kit. You willpay over 500 for the kit then have to buy head gaskets still. For what is it that sale I can get for you. Injector seal kit for both sides is 52.00 and shipping that's all coopers oring and banjos. The manifold gaskits can be reused but if needed there 35.00 ea. The gaskets for up pipes are 10.00 ea. Water bridge cross over gaskets are about 3.25 ea. Head gaskets 96.00 ea. O rings for rear of block for adapter takes 2 there 7.80 for both. Front main seal 38.00 rear main seal 40.00 Gm gray sealer 16.50. Little odd and end oring for the oil cooler and oil pump front cover top of water pump to cross over around 30.00. There is a o-ring that goes into the front of the oil cooler they think alot of list is 39.50 it 28.00. You also need your flywheel bolt there 18.00 for the set of 8. The balancer bolt is 14.25. The new cam bolt is 11.00. If you need the intake bridge gaskets that are is that kit there 4.50 ea. Injector cup seals are 26.40 for all 16 of them. If you need the lower valve cover gasket there 35.00 ea.
So for about every gasket o-ring and seal and the bolts on the front and rear you need would run you 599.45 plus shipping. If you needed the last 2 lower gaskets for valve covers that puts you at 669.45.
I will have the prices for rings today also on STD .20 and so on and if there back ordered or not.
Also if anyone look bears cost for H series are.
Mains 149.00
Rods. 227.00
thrust 39.00
1,836
Thanks Henry nfor taking the time to look that up. That was EXACTLY the info I was looking for. I want going to buy that kit on Ebay, but it sure did look promising as something for us to look into thru here. Glad you cleared that up. :thumb:
ripmf666
15,123
14
47
Wentzville Mo
your welcome sometimes you can find some dmax gasket boxes for sale on there buy it for 40 to 80 bucks and get lucky or not lol.
Cougar281
1,805
249
St Louis, MO
I can't speak for all the prices Henry quoted, but if the Injector seal kit is any indication, they are some really good prices. one injector O-ring at my locak stealer is $8! you can only buy 6.5 of them at that price (entire kit would be $128!) for the price of the entire kit from Henry.
Henry, I'll be contacting you for gaskets and such for a LBZ headswap, and probably more stuff down the road.
ripmf666
15,123
14
47
Wentzville Mo
Just let me know when your ready and we will vet your list worked up. I just started getting a few othr gaskets cheaper.
