Engine Bay
Philtopgun
Nice n Easy
May 5, 2007
710
45
Edmond,OK-still a Texan
Damn Im jealous. I just took mine this weekend to the car wash and washed the engine bay. I put it on the soak mode for low water pressure and spray the motor while its running. First note, I started the truck and drove straight to the car wash, turned her off and sat there for a bit. Temps were about 150. Then I turned the truck on and soaked the engine bay. Then I rinsed without squeezing the handle for extra pressure.
Begining of the year I used a soap bucket with a rag and wiped everything down in the engine bay, then used the garden hose fer a rinse. The car wash is a quick dust off. Need to take pics. First I thought you had to use some type of dressing, but you dont, it shines nicely without anything.
LT1BRD
sidelines expert
Mar 25, 2009
614
40
San Angelo, TX
there's a module on the right side of my LB7 with a sticker that says to not get it wet. are they lying or will it mess up something if i sprayed down my engine?
SmokeShow
6,818
Lawrenceburg, KY
Wayne, guess you DO still check in here every once in a while! You still got the puller? Been doing any pulling this year? I can't remember seeing you in any of the results threads. Thought maybe you took the year off to build up for next year or something???
C-ya
fordt
Think Done Deals
Jan 3, 2007
377
Vero Beach, FL.
www.abcamping.com
I have been busy, moved back to Florida, moved into a new house, moved our offices here from Ohio, etc.
I sold the LB7 back in March, IIRC. Sold it to a friend in Hamburg, PA. They are using it for a DD. I still have the motivation to do some pulling, but here in FL. there is not enough to warrant a build. One day, but not tomorrow. :baby:
fordt
Think Done Deals
Jan 3, 2007
377
Vero Beach, FL.
www.abcamping.com
If something shorts out don't blame me!
I have never hada single problem with washing the motor. I was h it maybe once a month. I hose it down, spray degreaser/cleaner on it, let is sit then scrub it with a brush. I just rinse it down after that, blow it off, let it sit in the sun then spray Undercarriage Spary form Adams on everything. Dirt don't stick to it!
