Engine and transmission build!!!!!
dirtymike1988
May 17, 2014
17
Denver
I have a client who wants to go fast with his 08 lmm we are thinking 600 rwhp to start.
Ats stage 6 rebuild or suncoast rebuild kit with billets shafts and flex plate
Efi live by korey Willis
Exhaust manifolds and pipes dpf delete
Egr delete
Fass fuel system
Head studs
Down pipe
Intake
Maybe nozzles or cp3 beefed up
Anything else I'm missing I don't have my list with me so I might be
Gonna be a fun job plan on pulling engine and transmission together without pulling cab (out the front):D
Lparrill
And here we go again
Jul 30, 2010
445
9
Lander, WY
I'd say keep it simple
Built trans (not ATS)
Lift Pump
EGR Delete w/ LB7 up pipe
EFI Live
Turbo (twins, fixed geometry or a badass Danville 68R vgt)
Injector nozzles (40% over +)
That will be an easy 600hp with a healthy CP3. IMO no need for billet shafts, flex plate, head studs or manifolds and up pipes until he gets in built motor territory.
quadracer37
Mar 31, 2009
547
northern, IL
Egr delete
Fass fuel system
Head studs
Down pipe
Intake
Do not need nozzles, cp3, manifolds, or head studs to make 600hp.
Trans- NOT purple, Tunes, fass, turbo upgrade- either compounds, or single.
Awenta
4,090
CT
Save the money on billet shafts and go with compounds
Hernpj01
On a Time Out
Sep 23, 2014
403
Indiana
suncoast trans
lift pump
all the bolt ons and delete parts
and a danville vgt charger 3794 or 4094 stg2r
Leave the motor in the truck no need to studd it or manis and uppipes
Lparrill
Jul 30, 2010
445
9
Lander, WY
Are you ordering an already built trans? If so can't go wrong with Mike L. @ Inglewood Transmission or Suncoast
dirtymike1988
May 17, 2014
17
Denver
We have future plans we will be buying a kit and building ourselves we run a heavy equipment component rebuild shop and have built Alison's as well so not worried about the teams build I just need to know best clutches and stuff. This guy has a lot of money so he will want faster in the future so doing head studs and nozzles pipes no turbo (yet) deletes intake Efi live lift pump gauges I think that will get a good start on a build truck may not pull engine may pull cab with a lift still thinking gonna start ordering parts Monday:thumb:
1,802
Again....NO NEED to pull engine, cab or anything else other than trans unless you're going to build the engine now.
Listen to the guys above. This isnt our first go-around here.
Trans....do your friend a favor and have a competent Duramax-related Allison performance trans shop build the trans. There's far more to it than just "stuff", and no good builder is going to tell you their secrets. IIRC, Wade @ DDD is pretty good.
Turbo, turbo, turbo. No point even starting if he's not going to add that, b/c he'll be disappointed without it.
Awenta
4,090
CT
Turbo isn't really optional. You'll have a hell of a time getting 600 without any turbo work.
