Well, I guess I FAIL! :rofl:
According to the instructions to enable the TPMS, You're supposed to go to go into Chassis > Tire Pressure Monitor > Special Functions > TPM Option Enable, then press exit to leave the menu and save the settings. Well, mine says NO. The "Commanded Status" changed to "Enable", but when I exit, it doesn't stay. So my guess is that the BCM helps to control the system, and that's what's not allowing it to enable. So is there a way to update the BCM and add the functionality (through TIS or whatever)? Thoughts
Edit: That's odd.... Looking at CALID, it has the following:
15120179 - 0000ED6E - New calibration to increase Tire Pressure Monitor initialization time.
Seems like the BCM has the calibrations to support the TPMS, so what the heck?
