Is anyone out there running one of these kits?? if so how does it run? Mpg? Power? just havent heard much on these in a while
I certainly like my custom one off kit, the custom 12" 10 rib pulley cost $650, rebuilt procharger $1200, 3/4" thick aluminum bracket (I made myself) $35 from the scrap yard, pulleys, idlers, pipe, etc. lets say $1,000 at the most. I'd say its doable on the cheap but then again I would rather make my own twin turbo kit than spend the outrageous prices for complete kits.
I dont have any track times for mine but hope to later this summer after the solid axle and 4 link go in. I will say I like it better than my old set of twins.
Just drove from our shop to a friends shop in laramie wyoming what once took 3 tanks of fuel one way, Same truck same wheels and tires same load, just added the procahrger kit to it now did it in 2 tanks. I would venture to say that right there is quite a bit of info for MPG. Going over mountain passes never once seen excessive smoke or EGTS get over 850deg. running 80-85mph.
Just heard from a customer that they just did 800hp and 15?? FT. lbs. with the F1R and GT42 setup. Had a hard time keeping the truck on the rollers due to excessive throttle response and only got the truck up to 60-70% throttle. Numerous Pulls and pretty consistent on the dyno numbers :thumb: This same setup can be put on a truck and tow or do whatever you want to do with it!!!
