electrical problem.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
After I did my cab swap I am having a issue. If I turn my key a little the odometer works. Once I put it in the run position it goes away. My wipers, overdrive, fuel gauge, coolant temp and trans temp don't work. My tach, speedo, voltage gauge, turn signals and hazards still work. My display always has the battery display on it. Fuses are all good. I looked and made sure everthings plugged in. Any ideas?
i_keyser
DD n00b
Jun 4, 2010
160
Denver
Sounds like the power moding is not right. Did you have the ignition switch out? It could be the problem.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Still chasing this issue. When checking stuff and making sure grounds are correct I ran by this piece. When I pulled it out my cluster worked but a couple relays made buzzing sound. Has a group of black wires running to it. What is this? Thanks
jwrkansas
117
Looks like a ground terminal looks to have about 6 circuits going into it. I'll do some Looking at a schematic to see what ties into it
