I started my truck 2x today and it started hard both times. First time was to move out of drive way so it didn't run long. Second time I left it running since the voltage was fluctuating down to below 12V. After 5 mins or so of idling, it was up close to 14V but still fluctuating a little. While truck was idling, I checked the voltage with a digital multimeter, 1 was 13.5 and other was 12.5. They were both fluctuating a little bit. I had 14.2V at the terminal for jump starting. After shutting the truck off, I had 13.5V on the battery reading 14 earlier and 12.5 on the other. The batteries are around 1 yr old. The glowplug light did come on before starting it the 2nd time so the glowplugs could explain the fluctuation. It was about 85 degrees today so I don't know if gridheather or glowplugs would be drawing that much. I have a long trip coming up in a little over a week and want to make sure I don't have any break downs.
Thanks.
Thanks.
