2001 allison has been staying in 5th gear......only way out is to shut down & restart......set a p1721 code.
After scanning all the normal "diesel forums", I find a couple of gents at another "place" had similar issues.....the problem being shorted wires &/or bad connections.
So taking the advice I gleaned from one of those threads, I pulled the red connector at the TCM, and check each pin for a short to ground. Pin 13 is grounded......apparently connected to the pressure switch because pin 13 is no longer connected to ground when I disconnect that plug.
Do I have a bad pressure switch?........or is this how it should be???
