I am having some issues that i cant pinpoint the cause. I have relocated the battery on our 05. Also removed the entire HVAC system and any associated wiring, the bose module, the XM/ONstar module, etc. Made my own pos batt cable, my own power cable to the underhood fuse box, and reused the oem alternator cable. Reused the OEM negative battery cable and left the grounding spots the same. Reused the starter positive cable too. Transfer case and front diff are not in the truck currently, so they are not plugged in.
The issue is that once i connect the battery back up, everything is normal. Until i turn the key on. Random lights light up on the cluster. Check engine light stays lit after first ign cycle even after key is turned off. Battery light is on with key on. Also, the lift pump runs non stop with key off as well, but doesnt run until the first key cycle after hooking battery up. Taillights are on even when supposed to be out but parking lights light up just as bright as brake lights. Pwr windows dont work regardless of key position.
Any ideas??
Any ideas??
