Electrical bug-dash problem
Nightlb7
175
Maryland
So my dash cluster is randomly changing languages and my steering wheel controls intermittently work, Iv checked connections and all the basics, my question is would this be a bad cluster causing this? Or more likely something with the steering wheel controls? Iv been having this issue for a while now and have not found much on the solution to this but have read about several people having this issue.
03 2500hd lb7, ccsb, robs trans safe tunes, Airdog 165, profab horn, 4in straight piped, ppe gauges, cognito control arms and braces, banks big head waste gate, batmowheel in the stock IHI. Built trans and engine coming soon :)
Nightlb7
175
Maryland
Nobody has had this problem??
Nightlb7
175
Maryland
Thanks that's the most info Iv seen yet, now if I can find out if this cluster is causing the steering wheel controls to act up
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I was going to suggest un plugging your cluster to see if it changed anything. But unless your loosing radio controls too you won't know.
Also not sure if steering wheel controls run through the cluster otherwise or through the bcm..
Nightlb7
175
Maryland
I have a aftermarket stereo and haven't connected the swi jack so I don't have steering wheel controls at the moment, I talked to GM gauge guy and he said to swap cluster with a similar truck "which a friend of mine has the same truck" and see if it goes away, so I'm going to try that this week
