Help: Electric worm
wheelie man
May 13, 2012
Huntington Tx
hello fellow maximizerz i am a new member to this forum. I have a problem with my 03 2500 hd. 4WD If i hit a bump in the highway the servive brake system comes on and the speedo fluxuates about 5mph from traveling speed, i have a triple dog programer all the dtc's are the same every time, speed sensor a, transmission mil request, and control module long term memory performance. She jumps into limp mode" third or fourth gear stick" and you have to pull over put it in park kill the engine and start all over... Any advive?:confused:
AubleAK
Aug 5, 2011
781
30
Glennallen, AK
Have you replaced the speed sensor? Input or output sensor? A friend was having a kind of similar issue, we went over all connections with electric grease and the problem never came back.
wheelie man
May 13, 2012
Huntington Tx
Yessir just changed the output sensor this am. Gona get out the ol pocket knife and get to work cuttin the loom apart to see if i can find a broken wire or loose pin connector.
