Work is slow today and so I've been pondering a few projects I wouldn't mind tackling. In my ever pursuit of making my truck a "do-everything" type of truck I have stumbled upon a few questions on something I would like to try. I was curious if anyone has setup an electric boost controller that would tie into the signal output of the Garret speed sensor? My small turbo is a GT3788 with a .89a/r housing. It is very easy to overspool. I have a typical mechanical regulator controlling the gate that I have set based off of the turbine shaft speed gauge. Works very well for normal conditions as I can keep the small charger in it's perfect efficiency island based off of speed and pressure ratio. However if I change elevations obviously the pressure ratios change and the wastegate needs to be reset. A few weekends ago I hauled my camper over Trail Ridge Road here in Colorado which is like 12,500ft elevation. On an 800us pulse I could easily push the small turbo passed it's operating rpm, so it got me thinking into this project.
This isn't really a problem I'm experiencing, more so a challenge that I would like to wrap some thought into. Curious if anyone else has experience with electronic boost controllers, diesel related or not.
