EGT probe hardware
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Im trying to wrap up all the little things on my truck. I forgot when i took my probe out of my manifold the threads on the prob are kinda pulled alittle bit. Wondering if anyone has had this problem and what they did to fix it. I thought about tryin to find a 1/8th npt die and seeing if that would work. I tried getting on jegs and seeing if i could find the fitting that screws onto my pyro probe but wasn't very successfull. iirc my threads in the manifold are still fine just layed over the threads on the probe. I need to mess with it alittle more now. Im guessing its going to blow out of the manifold with alittle bit of pressure :eek:. http://www.jegs.com/i/Auto-Meter/105/5249/10002/-1 I think this will be my last option unless i can fix what i have?
Texas Chevy
1,103
Vista, Ca
What guage is it? I have te cobalt and to get a new fitting an the set screw for mine I had to call auto meter cause the link you have displayed in your post didn't work with my type of guage. Auto meter told me they Didnt sell that part but sent me one. Free
kjp800
Aug 6, 2008
525
New Jersey
I had the same problem with mine when I put the 4500 manifolds on. I got a pack of 5 compression fittings from either fastenal or mcmaster Carr and they worked great. I'll send you one if you need it, I don't need all of them
