egr problem
dmaxmathis
Oct 17, 2010
31
North Wilkesboro, NC
hi all, today my check engine came on and i have it checked and it was the egr sensor.. what can i do to fix this and stop it from throwing a code? its an lbz..thanks
Iceman56
Jan 19, 2009
867
Madison, SD
Fill out your sig so we can help you better.
Do you have a tuner?? I take it you have exhaust and that is what is setting the code
dmaxmathis
Oct 17, 2010
31
ha i dont even know where the signerature thing is on here man.. and ya got a straight 4" and intake and probably next weekend going to get efi live and im going to get a edge programmer/monitor.. thanks for the help
Iceman56
Jan 19, 2009
867
Madison, SD
if your getting efi just block the codes and disable the egr problem solved.:D
X2 get a programmer to delete codes, its just throwing it cause your exhaust its not hurting anything. You can erase it but it will come back sooner or later unless you get a tuner to delete it or do the "fingerstick" which involves some wiring
Iceman56
Jan 19, 2009
867
Madison, SD
Click on "UserCP" in upper left corner, skroll down to "edit signature"
