LBZ: egr delete?
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
I have an lb7 up pipe and just purchased a profab egr delete kit. My question is will the lb7 up pipe bolt directly up on place of the stocker without modification? Also do i need new gaskets for the up pipe?
Tony Burkhard
Allseason Diesel Per.
The LB7 up-pipe will bolt up directly but if you use your stock down pipe it wont bolt up to the up-pipe. So if you use an aftermarket down pipe you will be all good. I offer a modified up-pipe that your stock down-pipe will bolt up to. My modified up-pipe is much cheaper than a new LB7 up-pipe. Some times the gaskets can be reused but if they look rusty and flat than they should be replaced. How many miles are on your truck?
07bluelbz
Sep 6, 2009
742
Beaumont,Texas
Thanks guys and Tony I have an aftermarket down pipe already. My truck has 84k miles on it but in Texas we really dont have the corrosion problems like up north so the gaskets may be flat but nothing is rusted on my truck so far.
