Egr blocked by soot
Oaxaca
May 30, 2016
I removed the EGR since I develop a leak on the Y pipe and found the EGR blocked by soot. Any recommendation on EGR and DPF delete?
Not looking for extra HP or torque just a cheap delete kit.
https://photos.google.com/album/AF1QipNjdxxSuXJSaEcsQYsxJLbWAfkdA9mUpPpR7qYw
2007 LMM
Thank you
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Do NOT do a cheap delete. Blocker plate or plate kit on cold side pipe and lb7 up pipe. Or at least cut off riser and weld it shut. The plates they sell to cover risers cause major head aches
Oaxaca
May 30, 2016
Thank you, ill try and take out the down pipe cut and weld.
2,136
Why not just clean it out and reinstall it? Does your state do emissions testing? If so you'll want it in there
Oaxaca
May 30, 2016
No, VA does not require emission for diesel engines but is a good idea no harm on cleaning and reinstalling it.
Thank you!
