As posted on our forum, Dan's Diesel Performance and Power Performance Enterprises are holding tuning classes in Kinder, LA on March 3-4.
EFILive Class in Kinder LA March 3-4th 2012, Duramax and Cummins
Cheers
Cindy
Dan's Diesel Performance and Power Performance Enterprises is hosting a EFILive class March 3-4 at Coushatta Casino Resort in Lake Charles LA. It will be a two day class with dyno on site.
Day 1 is the beginners class and will be directed towards getting your software installed on your computer, registering your V2, Reading tunes, Cal Flashing, Full Flashing, Data logging, etc. We'll show you how to read a stock tune and make adjustments to create a tune on a stock turbo and injector truck. Then flash it in. Also we'll go over the EFILive products and how to order licenses, etc. We'll go through the data logging and how to set it up and use it to help create tunes. We'll go over using this on Duramax and Cummins.
Day 2 will consist of taking your tunes to the next level. We'll go over what it takes to dial in big injectors and turbo setups. We'll demonstrate making the trucks run the way they should and how to adjust certain areas of the tunes based on feed back from data logging.
Dyno on location. The plan is to have a dyno at the class so students can see the affects of the tune changes on the dyno and how the trucks respond. We'll also go over what it takes to make max power out of the truck and how to build better tunes based on dyno and data log results. Also given enough time you'll be able to run your truck and see what you have for a small fee or dyno tune it as well. Fees haven't been decided yet. Then the Monday after the classes we're thinking of having a dyno competition. (stay tuned for details)
Day 1 for Beginners is $250. Day 2 for Advanced is $300. Or buy both for $500. Where you stay is your choice. The hotel we have is top notch and has restaurants and casino on ground floor, but there are other hotels in the city. Hotel and food fees are not included in the price.
If you have a non EFILive tunable truck you can come as well for the dyno event. If you want to learn the software the prices are the same.
Let us know if you have any questions. Contact Dan Clarke at [email protected] or Kory Willis at [email protected] to sign up. Class will be limited to the first 50 students. Discounts will be available for Coushatta Casino and Best Western Inn next to Coushatta for students. V2s, Autocals, DSP5 Switches and Swag will be available for sale as well.
Cheers
Cindy
