EFI tables, which ones?
Redbone
but this one goes to 11
May 1, 2008
261
Indy, IN
Been browsing through EFI, getting used to the landscape, and ran across some questions on tables with similar parameters:
1) On the base injection timing tables, there are five separate ones, A-E. The notes say that Table B is the most common table used most of the time during normal running. Under what conditions are tables A,C,D and E referenced?
2) References are made under several calibrations to High, Medium and Low altitudes. What are the differences? Where does Low altitude end and Medium begin?
Thanks!:baby:<------EFI Newb, me
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
There is a "TIMING TABLE" PID that says which table you are running on. Normally these tables are altitude related, but I seldom if ever see it in any table other than B.
The altitude 'breakpoints' are programmable. See B0202. Unlike earlier O/S's, this method can "feather" from one altitude to another.
If you want fixed altitude tuning, just make SEA column all 1.00, and the HIGH / MEDIUM columns all zero.
