EFI & p0087 ?
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I get a p0087 about every other pass right at the end of the 1/4mi. Is there something I can change on EFI to mask this problem (where)? Maybee changing the limit of the Cel to come on a little later. I would try and fix the problem with tuning/loging, but my laptop is not working correctly, and im doing everything on my home CPU.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Under engine diagnostics Russ you can turn off both the enabler and the MIL. But you should be able to tune it so that you arent draining your rail so bad. Have you logged any 1/4 mi runs?? How many ms pulsewidth are you running?
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Can't log any run's yet. the 40' of USB cord (to home cpu) already cost me $80, might need 1/4mi. of 110V extension cord this weekend, so I can load up my home cpu in the pass. seat:D sending you a PM now!
624
p0087 is a low rail pressure code
just liek the p1093 on the LLY motors..
need with a lift pump, change filter, or cut back pulse width or a combination of the above.. or dual fuelers:cool2:
13,736
806
Wheres the trusty black box when ya need it??
It works. I've been using it for about 4 weeks now.
What kind of pulse are you shooting with your tune? Maybe try backing it down some. If your rail is dropping that low, you're probably hurting yourself more than helping.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Im a V1 guy so ive never been deprived. Only time in my life being cheap helped me out haha. PW was around 3250.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
try backing up to 3100 :)
I backed it down to 3120 for him. The trucks always done it on this tune its not related to a fuel filter or anything, just too much PW for his particular CP3. See how that does and go from there.
ripmf666
15,123
14
47
Wentzville Mo
I will be digging into mine tommorrow aslong as ups shows up with the modded regulator hehe then I just have to wait for Pat to send me a tune to fix the idle and cruise issure he said I might have.
