Hello all I installed an EFI tune in a 2005 LLY. The o.s. did not match the stock file o.s. I had problems with the accellerator pedal having to push it half way to accellerate. Just for a test I had another tune for LLY that had the same o.s. # of the stock file so I loaded it. It cured my problem and pedal was good truck ran great for a bit. I was on a test drive and on my back and the check engine light came on and injectors started to make lots of noise? I pulled over checked the codes and had a p0202 and p2149? I cleared the codes and started the truck and continued on. The truck ran normal with no light? My question is do you see any problem with o.s. #'s of stock file and different o.s. with installed tunes? Thanks, Randy.
