I was wonderif if any one has ran into this i have the beta bb logging and my truck will not read any dtc in the flash scan or on the v2 it will clear the codes no problem load and log fine but will not display dtc any ideas thanks
Mine works on an LB7 but takes forever to retrieve them on an LLY. And when you finally get them to show up on the LLY when you try to clear them it takes forever, says codes have been cleared then the light goes out but the codes are still there...
Haven't tried an LBZ yet though.
We've just released an update today - and there has been lots of changes made. Hopefully this issue and your DVT issue are now resolved. I can't say that I've seen the clearing codes issue reported elsewhere....
I find on the LMMs I have to read the codes twice. First time will report no DTCs when I can clearly see the SES light illuminated. Second time displays all the codes.
well I did the new download and now i can read dtc on the v2 only but not in the flash scan tool I have clicked it 2or 3 times to no avail but works fine on the v2
yea i have same problem with the beta...takes two times with my lbz for it to say there is codes and then when i try to clear them a error comes up on my v2 but the ses light will go away...
