Edge Juice Module
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
I think in the box under the hood. I think there is a plate on the side of the module iirc an remove it. there should be little switches behind it I think.
JMDuramaxLB7
YOU SAID MEMBER!!!
Jun 3, 2007
744
Missouri
Seems to me it has something to do with shifting from park to drive, once for level one, twice for level 2 and so on. The engine will surge when you change the tunes, once for level one and so on.
Dazedandconfused
Lost in the diesel smoke.
Jul 26, 2007
225
Nothern Ky
Thats what I thought to and we were correct. I finally found it on Edge's site.
NOTE: If you have the Attitude installed, the following procedure does
NOT apply. Power levels are changed using the Attitude.
1. Set the Parking Brake
2. Turn key on without starting the engine (engine must not be running).
3. Select the desired transmission mode to set the power level for (Normal or
Tow/Haul).
4. Place gear selector in the gear corresponding to desired power level (D=4,
3=3, 2=2, 1=1, R=stock).
5. Press accelerator to the floor two times, completely releasing the pedal
each time.
6. Return gear selector to Park and start the engine.
7. Press the Tow/Haul button twice. This causes the Juice module to
“remember” the level setting for the mode.
Power Level Confirmation
To confirm the power level that is selected:
1. Place gear selector in Park with your foot off of the accelerator while
engine is idling
2. Set the Parking Brake
3. Select Normal or Tow/Haul mode, depending upon the transmission mode
power setting you wish to confirm
4. Place gear selector to reverse, neutral, reverse, then back to park. P-R-NR-
P
5. The engine will rev to coincide with the power level selected, revving 4
times for level 4, 3 times for level 3, and so on
Dazedandconfused
Jul 26, 2007
225
Nothern Ky
I'm just glad I figured it out. I wish it wasnt so lazy until boost hit. It does it stock and with the box. Are all the LLY's like that?
