LLY: Edge Insight users
madmax02
Apr 30, 2012
88
Taylor, Mi
How do you guys like the insight CTS? Are you guys running any options besides the egt probe? Does it seem pretty accurate?
AdaMax
Nov 26, 2010
412
Caldwell , Oh
I like mine . It comes in handy when you are in my sled pulling knowing what my max rpm is and boost going down the track . Being able to read codes without hooking any thing else up is nice too .
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
I like mine. I run the EGT and have a cheapo backup camera. Works well, no issues.
It reads data from data stream, so yes it is accurate.
diesel53
Sep 16, 2010
907
AZ
Compared to?? Its the best digital set-up that I am aware of. Numerous parameters to monitor and you can check your LB7 balance rates
duramaxJoe08
smokinjoe
Aug 27, 2011
35
Princeton Iowa
I like Mine. I run egt and also have it hooked up with efi live so i can change tunes with the button also it is nice to have five gauges in one area.
dieseltwodoor
Apr 13, 2010
189
Alberta
I like mine.
Mystyle and software updates don't work on Mac. No response from Edge on when they plan to change this.
Get it on
Got to get it on!
No choice but to get on!!
Mandate... Get-it-on!!!
jacobdewey
This won't last long...
Jan 14, 2011
972
I run egt, boost gauge, and working on an engine oil temp gauge. I go through alot of egt probes though... about one every 6 months. Other than that I love it. Getting a cs for my lly to go in the overhead console. They read boost off the map sensor, and it maxes out at around 25psi, so I bought the expandable kit with the universal hookup and I already had a 0-60psi sender sitting around. I hooked it up, calibrated it and it works great.
