Edge attitude overhead console
duramaxrize
Dec 4, 2011
53
kitchener, ontario
Can anyone help me. Right now I have an edge with attitude it is mounted in my overhead console. I am going to an EFI live and an edge cs for monitoring and switching levels. Can i use the same overhead mount for the cs? Thanks:)
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
The cs is phsicaly larger i believe and i dont think you can get it in there i saved my cubby hole thing incase i had to put it back some day but i just mounted my manifold presure gauge there and i stuck another dumby gauge in there to fill the other hole in the 2 gauge mount as im sure i will add another gauge at some point in time.I loved my edge monitor up there
duramaxrize
Dec 4, 2011
53
kitchener, ontario
Anyidea how much larger? Could i just cut it out a little larger?
dbev24
390
Darlington pa
It's like half an inch larger taller and wider. U might be able to fab the old mount I'm not sure but I just put in a aluminum mount from ats for my attitude and if I remember they had one for the cs to.
JDub
607
Hooper, Utah
Edge offers two different Insight monitors. The CS and the CTS, the CS is the same size as the older Attitude screens, so it should be a direct swap. The CTS however is much larger and would require the above linked adapter, not sure you have the clearance on the upper console for the CTS though. You may also have to ask Edge about a longer OBD to monitor cable...
duramaxrize
Dec 4, 2011
53
kitchener, ontario
I am getting the cs. Everyone i have talked to ordered the longer cord and didnt need it . So im not real sure what to do.
taylorbok
go with the cts, i have used both the cts is way better easier to read and you can view more gauges at once, put it on your dash if you are worried about fit in the over head compartment
