edelbrock 1792
stacks04
792
Terryville,Ct
warranty voided now with diesel fuel:
Quiet-Flo™ Electric Fuel Pumps
Manufactured by Essex Industries, one of the most renowned fuel system manufacturers, these state-of-the- art Electric Fuel Pumps offer maximum performance in a compact package. With anodized aluminum housings and high-quality internals, they are both strong and durable. Each pump is factory-tested and includes mounting brackets. The carbon fiber vanes and composite rotors give these pumps the added boost for maximum performance. The high quality construction results in a pump that is 4 to 14 dB quieter than competitors pumps at the same pressure. #1791 is factory preset to 6.5 psi and no regulator is required. With a replaceable screen type inlet filter and the free flow rate of 120 GPH is sufficient to supply 600 hp. #1792 has a free flow rate of 160 GPH, enough to feed a 1000 hp engine. This pump is factory preset to 12 psi and requires an external regulator such as the new Edelbrock regulator #1727. *Warranty will be voided when used with diesel fuel.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
This is true for most the "mainstream" pumps sold through Summit or Jegs. This is not new. When I first ran a 1792 back in 2005, it was not warranteed for diesel.
