Help: ECM pins?
Dec 2, 2006
1,696
TN
So I installed my high idle switch for my LBZ, well in the process I accidentally jerked a couple wires out of the slots. Now I have no cruise control. I though I pushed them in correctly but the pink slide lock didn't want to go on very well. Since I pulled a couple of wires out, are those pins made to go back in?
770JOHNNYW
Sep 16, 2009
791
Gainesville ,Ga
when you pop the plastic clip off the connector you should be able to slip the pins back in there and then just clip the retainer back on the front of the plug.....
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
x2
Have a small needle to help you make sure they are seated.
that sucks to have to rip apart tghe connectors again.
Hows your high idle working??
Dec 2, 2006
1,696
TN
x2
Works fine. Cruise works, but, when the truck goes to accelerate to keep up to speed, the trans downshifts and doesn't add any throttle, and just keeps downshifting... :confused:
