Is there any differences between an 02 and 03 ecm.I swapped an 03 for an02 then the truck would not start .whats the problem???
VIN mismatch would be my guess.
You can also reprogram it with EFILive. You don't even have to burn a license to do it.
Josh how do you do this if you dont mind sharing :hug:
http://www.duramaxdiesels.com/forum/showthread.php?t=2035
Look at the first part I quote from Cougar in the above thread
FlashScan can be used to reprogram the VIN in the engine and/or transmission controllers if desired. Reprogramming the VIN in a controller does not require a license.
