What are these emissions testing you speak of?
Any recommendations on a set of 100 over injectors
We use Dynomite Diesel (DDP) here at my shop as our main source. They are running a 5% sale 11/24-11/30.What are these emissions testing you speak of?
the by-annual smog test mandatory for all diesel vehicles in California from 1997 and newer that are 14k lbs gvwr or less.What are these emissions testing you speak of?
Depending on the countythe by-annual smog test mandatory for all diesel vehicles in California from 1997 and newer that are 14k lbs gvwr or less.
those six counties that don't smog test still require an inspection so there's thatDepending on the county
Are you sure? I wonder if it’s up to the county because I’ve never seen it donethose six counties that don't smog test still require an inspection so there's that
it's possible I've misunderstood the text but even if there are exempt counties there are still a large listing of zip codes within them that still do. the exempt list is getting smaller each yearAre you sure? I wonder if it’s up to the county because I’ve never seen it done
