I have just recently changed my turbo set up from a Danville 72vgt over a s484(96mm/1.32ar) to the new Duramax stealth s467.7 over my s484. I broke the shaft on the 72vgt so I figured I would up grade to the s400 with a bigger shaft and try a fixed vane. With this new stealth 67.7 (83mm turbine .80ar housing internal gate)that Duramax tuner just releasted seemed like a great option for and not having to get a new twin kit or make a bunch of changes to fit a s400 style charger in the valley just had to change my hot crossover pipe and it has a internal gate and uses a stock style pedestal. So On the Old set up (72/84) I would see about 80psi of boost, 1400*-1500* egt's and on the new set-up (67.7/84) I am only getting 50-55psi of boost and if I pinish off the Wastegate line I will see 65psi of boost. The waste starts to move at 20psi and is fully opened at 45psi. I have a low pressure boost gauge coming from the 484 and I am seeing about 50 psi from the s484 is that normal? My egt's are high I can hit 1800* on the street on the 5 tune and I have checked for boost leaks a few times (plugged and pressured tested the big turbo) no leaks. sorry for the novel but does anyone have any ideas???
