Problem is anything less than the 2" spacers (bolt on or wheel lugs re-studded) will require you to cut your stock studs. Putting say just a 1/2" spacer ,no studs, won't leave you with much left to bolt on the wheel.
A 1" spacer is ideal but you'll have to cut wheel studs resulting in never returning to stock
