Dually conversion
Jacy_dzlguy
lots to learn...
Aug 27, 2011
257
32
South Florida
Hey guys i just bought a 08 regular cab and im wanting to put a flatbed bed on it and dually wheels. Can a just use the oem dually spacers up front? (number 5 in the picture) I have 2" freds spacers for the back. if thats not enough ill get 3". Is that all i need? Thanks:thumb:
ikeG
Oughta Know Better
Apr 19, 2011
2,465
147
Western PA
www.facebook.com
Those dually front spacer are what you need, yes. But a SRW truck's front wheel bearings have longer studs. They have the ones with the rounded tip whereas a drw truck's wheel bearings are squared off(little bit shorter). I think there will still be enough room to stick the nuts on to tighten up the OEM dually adapters. You probably will need a minimum of 3" spacer on the hub in the rear. Then whatever else is required between the wheels, if any.
Jacy_dzlguy
lots to learn...
Aug 27, 2011
257
32
South Florida
So 2" wont be enough? What about using the same oem spacers on the back?? Is that a stupid idea??:confused: THANKS FOR YOU HELP GUYS!
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
You can't use the front spacers on the rear. They will not fit over the hub.
I would sell the front pair of spacer/adapters for $150 shipped.
