Dually calipers
Diezel
30
Upstate NY
Will a dually rear caliper bolt up to a SRW axle? Currently in the process of swapping my dually to a single and changing out the rear end, the calipers that came with the new rear end are locked up so curious if I can reuse mine or have to buy new. Trying to place an order for everything I’m need at once but I’m not home and don’t have my truck so I can’t check myself.
Truck is question is in Sig and the SRW rear end is outta a 04 duramax.
Diezel
30
Upstate NY
Okay I’m just gunna go ahead and order new calipers. Anybody in the market for a complete dually conversion kit? Bed, axle wheels/tires :D
1,865
The calipers themselves may work (they look like they are the same to me), but the caliper mounting brackets are definitely different.
I would recommend checking what RPO code your current brakes are, and comparing it to the RPO code brakes you are swapping to.
