The CP3 controls how much fuel CAN be pumped into the engine.
The injector size controls how long it takes to spray it in.
We made 797rwhp at 4400? RPM on pump diesel with stock LiLLY injectors.
Unless you are a max effort sled puller, big Nitrous, or sub-11 second drag racer, spend your money elsewhere, IMO.
PS - I'm a dealer for Dynomite Diesel, I can get you injectors. I just don't recommend them to most folk.
With larger injectors, you don't have to run stupied amounts of timing with the stock injectors to achieve the same power.
While on the subject of dual CP3's vs. bigger injectors, is a guy "all in" with addition of either or both of these mods? At what point do you sacrifice drivability or any semblance of mileage, assuming of course you also have sufficient air and tuning?
