dual fueler
fishsmith
1,402
42
Monroe, LA
Got the dual fueler installed last night and holy heck what a difference.:eek:
I didn't realize how much of a difference it would make. Thanks Chad.
fishsmith
1,402
42
Monroe, LA
built motor with lbz pump in valley and supposedly 20 over injecters. 66mm bullseye turbo. I was losing rail pressure bad with just one pump. I just made a quick run last night up the road but on the same tune I ran a 13.4 on stock motor I was holding 24000psi steady. I'm going to the track tonight, so we will see exactly how much difference it made.
05lly2500hd
(903)293-6026
Feb 16, 2008
473
45
Texarkana, TX
well??
fishsmith
1,402
42
Monroe, LA
My lift pumps weren't keeping up when I would go full throttle. Made a change to the lift pump setup but haven't had time to run it yet. It gets plenty of fuel now though.:happy2: On tts lift pumps I went 13.1 at 108 with a 2.1 60ft Also have lockup controller to install.
05lly2500hd
(903)293-6026
Feb 16, 2008
473
45
Texarkana, TX
Did you change lift pump setup altogether or just make a change to what you're using? Best of luck. I'm dying for a dual setup.
fishsmith
1,402
42
Monroe, LA
I changed lift pump setup all together. A lot bigger pump with a bypass around it so I only run it at the track. I'm pushing 15 to 18 psi now at idle with it on.:D Sorry it took so long to reply
