Info: Dual Fueler Diagnostics
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
In this thread we put all the tips, tests, and ideas related to dual fueler issues. :D
Question, Whats common way to test operation of controller?
If you unplug 2nd cp3 regulator, what should happen? When I unplug nothing seems to change?
13,716
779
Question, Whats common way to test operation of controller?Does actual rail pressure follow desired? If so, the controller is working (at least in my mind that's what it means).
If you unplug 2nd cp3 regulator, what should happen?If you unplug the second regulator it should open that regulator and cause the rail pressure to go wide open.
That's my answers.
jpowel29
780
Bentonville, Arkansas
Best way to check your CP3 operation is log actual rail pressure vs desired. When my controller wasn't working I could only hold about 5800psi going down the track when the tune was asking for 25k.
