LMM: Dual fuel filter instal
2,110
Looks like it hangs down pretty low. Are you worried about it hitting anything and ripping off?
By the way. Here is mine
StormtrooperLMM
Lifted Stormtrooper LMM
May 5, 2016
15
Southern Cali
I have power amp steps so I am limited where I was able to mount it, I am not worried about it ripping off I am running on 37's plenty of clearance. If I did rock crawling I would be. I like your set up though it looks good!
2,110
Thanks.
I thought about going away from stock filters but i had like 10 of them so i thought why not. These are set up in parallel so less restriction and longer filter life
Ridin'GMC
I like red
May 20, 2010
635
19
MA
You can mount them inside the frame after the fuel tank. That's where mine is mounted, it hangs about 1 1/2" below the frame with my fuel/water separator, primary is hidden behind the frame. Much more concealed and better not to get hit when wheeling.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
That's a eye sore for a nice looking truck. I run mine on the inside of the frame and you can't see them. I also have the amp steps
