I noticed the other night my dash lights dimming with my turn signal. only extras on the dash light circuit is 2 autometer gauges(led) and an inline dimmer for those 2 gauges.
i have 4 130w kc daylighters on a single switch, when i turn them on, you can see the volt gauge dip and my lights dim, it didn't used to do that. you can hear it in the lift pump as well when the voltage drops.
with a meter at the battery it drops a full volt.
so on to the testing. I have a factory dual alternator set up. one of my batteries is about 5 years old, the other is 4(someone stripped the connections) it runs about 14.5v at each battery at idle with the headlights on. I turn the truck off, unplug the drivers side alternator connector, start the truck, still 14.5v at both batteries and from alt + post to GND tab.
I turn the truck off again, plug back in the drivers side alternator, unplug the passenger side alternator, start the truck again, battery light stays on and dic says "battery not charging" still getting 14.5v at both batteries, tested from + post of alternator to GND tab, still 14.5. voltage appears to be moving around like it's charging.
i tested it this way because that's what i found on google, and it made sense to me i think it was off duramax forum. does this sound like a legit test? apart from taking off the alternators and batteries and having napa test them, anything else to look at? right now i am suspect of my driver side alternator
sorry for the novel, just trying to give as much info as possible
