LB7: DTC P0463 Issue....
Sep 10, 2008
1,072
Morehead City, North Carolina
My Low Fuel Light on DIC remains lit and fuel gauge reads empty. Clear the code, fuel gauge reads normal for two seconds, then throws the code again & low fuel light comes on. Says "Fuel level sensor high input"..... Anyone ever have an issue with this before?
I've unplugged the sensor on top of fuel tank and light still stays on. Could it be a bad connection somewhere...? Any ideas?
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
DTC P0463
Circuit Description
The fuel level sender changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sender in order to determine fuel level. When the fuel tank is full, the sender resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sender resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sender in order to calculate the total remaining fuel (%) in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the instrument cluster in order to control the fuel gauge. The fuel level information is also used for misfire and EVAP diagnostics.
Conditions for Running the DTC
The ignition is ON.
Conditions for Setting the DTC
• The fuel level signal is greater than 98%.​
• The above condition is present for greater than 20 seconds.​
Action Taken When the DTC Sets
• The fuel gauge defaults to empty.​
• The low fuel indicator illuminates.​
• The PCM records the operating conditions at the time the diagnostic fails. The PCM displays the failure information in the Failure Records on the scan tool.​
Conditions for Clearing the DTC
• The DTC becomes history when the conditions for setting the DTC are no longer present.​
• The history DTC clears after 40 malfunction free warm-up cycles.​
• The PCM receives the clear code command from the scan tool.​
Diagnostic Aids
Use the Freeze Frame and/or Failure Records data in order to locate an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data may aid in determining the number of miles since the DTC set. The Fail Counter and Pass Counter can also aid in determining the number of ignition cycles that the diagnostic reported a pass and/or fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature, etc.). This will isolate when the DTC failed.
Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Test Description
The number below refers to the step number on the diagnostic table.
  1. Tests for the proper operation of the circuit in the low voltage range.
Step
Action
Value(s)
Yes
No
Schematic Reference: Instrument Cluster Schematics
Did you perform the Instrument Cluster Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Instrument Cluster
  1. Install the scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With the scan tool, observe one of the following fuel level parameters:
    Fuel Tank Level Remaining % parameter in the PCM Enhanced Evap Data list -gas only
    Fuel Level Sensor % parameter in the Engine Data Fuel System display-6.6L diesel only​
Does the scan tool indicate that the Fuel Tank Level Remaining % or the Fuel Level Sensor % parameter is greater than the specified value?
98%
Go to Step 3
Go to Diagnostic Aids
3
  1. Turn OFF the ignition.
  2. Disconnect C152.
  3. Connect a 3 amp fused jumper wire between the signal circuit of the fuel level sender and the low reference circuit of the fuel level sender (male terminal side).
  4. Turn ON the ignition, with the engine OFF.
  5. With the scan tool, observe the fuel level parameter.
Does the scan tool indicate that the Fuel Tank Level Remaining % or the Fuel Level Sensor % parameter is less than the specified value?
4%
Go to Step 6
Go to Step 4
Test the signal circuit of the fuel level sender for an open, a high resistance, or a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 12
Go to Step 5
5
Test the low reference circuit of the fuel level sender for an open, a high resistance, or a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 9
Test the signal circuit of the fuel level sender for an open, a high resistance, or a short to voltage between C152 and the fuel level sender. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 7
Test the low reference circuit of the fuel level sender for an open, a high resistance, or a short to voltage between C152 and the fuel level sender. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 12
Go to Step 8
Inspect for poor connections at the harness connector of the fuel level sender. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairsin Wiring Systems.
Go to Step 12
Go to Step 10
9
Inspect for poor connections at the harness connector of the PCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 12
Go to Step 11
Replace the fuel level sender. Refer to the following procedures:
Fuel Level Sensor Replacement in Engine Controls - 4.3L​
Fuel Level Sensor Replacement in Engine Controls - 4.8L, 5.3L and 6.0L​
Fuel Level Sensor Replacement in Engine Controls - 6.6L​
Fuel Level Sensor Replacement in Engine Controls - 8.1L​
Did you complete the replacement?
Go to Step 12
11
Important: Program the replacement PCM.
Replace the PCM. Refer to the following procedures:
Powertrain Control Module Replacement in Engine Controls - 4.3L​
Powertrain Control Module Replacement in Engine Controls - 4.8L, 5.3L and 6.0L​
Engine Control Module Replacement in Engine Controls 6.6L​
Powertrain Control Module Replacement in Engine Controls - 8.1L​
Go to Step 12
12
  1. Use the scan tool in order to clear the DTCs.
  2. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
© 2010 General Motors. All rights reserved.
dmaxfireman
Apr 8, 2007
2,329
CT
sorry the forum doesn't show the table. if you have trouble deciphering let me know and i can email you the procedure in a word doc
jc1843
Sep 27, 2009
228
86
So Calf
Yes, that part is made by Dorman-- and will work with a slight modification. It is usually easier to lift the bed, rather than drop the fuel tank-- that way you can test it when you add the new sensor.
MechanicalReign
Mar 8, 2012
108
Ohio
I Know this was an old thread but. I finally Did the $27 Dorman fix. Had no help With the bed just took bumper and wheels off so I can slide the bed back. I also just cut old one off instead of melting it. I tried making an aluminum base but made it real hard to put in. So I just carefully riveted it to the plastic directly instead. Used the old float and it went in real easy. Been Working great since.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
Mine used to do the dance if my truck sat still for more than 10 minutes. When I modified the fuel pickup I cleaned the sensor with clr and atf. When I reassembled it the fuel gauge worked perfectly again...
