I need a little help diagnosing what is going on since I had my truck all apart. I have no speedo, and it doesnt act like it is going into OD. My codes:
P0234-Overboost--I never even got on it, dont know why this comes up
P0500-Vehicle speed sensor--prolly why I have no speedo
P0700-TCM requested MIL
P1860-TCC PWM solenoid circuit
Any ideas what to look for? I have all my sensors plugged in, and I double checked them. Can the 2 on top of the tranny be switched? I thought most plugs only fit into one spot?
I have no copilot controller plugged in right now. I assume the tranny should work normally without it (just like it being turned off) but maybe not?
I also wired in OD lockout, Dsp2 and Dsp5. Could I have effed something up installing one of those? Can you run your normal tune with the dsp2+5 switches installed (I put the switches in but have yet to change my tune).
I tried pushing the OD lockout switch a couple of times but nothing happened. I also did the same with the dsp2 switch and the dsp5.
I hope I put this in the right place and I hope someone can help me or lead me in the right direction anyway!
Thanks!
Thanks!
