I have run/made scripts for the lbz/lmm multiple times...well i dont know if it is coincidence or if a update issue, but as i have always done i upgrade the stock file to dsp5, compare to the dsp5 i already made,,create script, then i run that script over the stock(dsp5) file...normally it populates fields 1-4 as does the base tune... however, i'm having a issue. It is only populating fields 1 & 2 along with the base tune and leaving 3 & 4 unpopulated.. i have not had this happen before can someone chime in maybe? When i compare the differences it is not comparing dsp 3 & 4...can someone maybe chime in why? Thanks!:thumb:
