DSP2 Switch??
wdino73
735
55
Versailles, Ky
I'm trying to learn about dsp2, with the switch off u load your base tune which has the dsp2 OS that has the cali mods, then when u flip the switch on, it reads the cali mods. Is that basically it or am I way off, I'm trying to change the tunes for my friend he just bought the truck an the switch worked so I'm just trying to learn how to tune it. thanks
darkness
1,315
379
vegas
yeah with the switch off it would be the base tune. all paramiters can be changed. with the switch on only certain paramiters can be changed. they are under efi live custom calibrations. the on position will use base parameters for the tables that cant be changed
darkness
1,315
379
vegas
i answered your pm. im not much help with that hehe. im sure someone with more knowledge will chime in
wdino73
735
55
Versailles, Ky
Yeah, I'm just wondering about the tune if it will work on the switch, If someone could look at this for me an let me know if I did it right, Thanks
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
What exactly are you trying to accomplish with it? I'd be more than happy to help you out if you need it. I've got a couple of good safe tow tunes that I run that have EGT's that are cooler than stock, and spool in nicely. They're onlyu about a 30-40HP tow tune though, but this will keep it stock trans safe.
EDIT: I took a look at that tune, and the DSP side is way to hot for a tow tune IMHO.
wdino73
735
55
Versailles, Ky
I was just won't to make sure that i had the setting right for the switch to work, I know I'll have to tweak the cali's just checking to see if I did it right, not so much the tune itself just the dsp2 part, Thanks Ferm
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I'll go over it tonight and add in a hot tow tune for yeah.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I didn't change anything on the base tune, just put in what should be a pretty stout tow tune. It can be made hotter, but this should get yeah enough fuel to have to watch the EGT's pretty closely with much of a trailer. And I only went 50% with the timing.
  • Warrren's DSP2 BaseTowtune-1.tun
