dsp2 switch install again?
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
Ok i need to know how to install this switch. Lets make it dummyu proof. First where is the ecm to plug it into . And i have an lly is this self explanatory. Is it blue to blue black to black then just ground the ground wire?
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
the ecm is below the tcm which is on the driver side between the battery and fan shroud. its easier to get to by removing the tcm first.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
or you can open up any of your tuning files, go to the help tab, then tutorial, then dsp upgrades for the same instructions, and they are in color.:D
Thanks :D I guess that is why I'm not the techie in the family :rofl:
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
Hey its a little further down then the ecu the ecu has a shord around it u have to go under the driver side battery. The reason i am telling u is because i was trying to but it in my ecu not ecm
dracing70
Jun 12, 2007
1,210
45
mantua, oh
those directions are great but it doesnt say which color wire goes were. which connector takes the blue wire which takes the black wire what is the output wire about and does the wire with the eyelet just get grounded? Or does each application only use either the blue or black wire. As i said my switch has 2 black wires one with pin one with eyelet and a blue wire with pin also one pin is shorter than other?
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
the black wire with the pin goes to pin hole # 1 on the blue connector on the ecm. The black wire with a pin is "NOT" used.just tape it up. I dont remember the other black wire with the eyelet, but if I was guessing, that would be a ground wire, just ground it as normal.
dracing70
Jun 12, 2007
1,210
45
mantua, oh
larry i have one black wire with pin one blue wire with pin and black with eyelet where does the blue go or is it not used
dracing70
Jun 12, 2007
1,210
45
mantua, oh
thats what i needed to know thanks. Are you in contact with mcrat. i was supposed to recieve my tune for my dsp and new turbo last night but did not and i cant reach anyone.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
only one wire goes into the ECM for a dsp switch llys and lb7s are different
the other shorter wire is for ground
DSP output is optional and not needed for DSP 2 or 5 to work
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
i just read the instructions for DSP 2 upgrade
why do they show hooking a ground for dsp 2 in the ECM?
i only used 1 wire and one ground under the dash
is it different now?
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
dsp came with 3 wires, lb7 used blue, lly used black and the short one with the eyelet grounds inside the cab close to the switch.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
larry have a look at the instructions in the EFI
i have never had a problom with installing the way i did it
just kinda see why this would throw a kink in guys installing it
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
Instructions are a little vague, I guess since we got ours installed we can't see any problems........ I figured installing my traction bars would be a snap, but guess what, they're being put on at the shop right now, and would you believe I got a GM Dealer doing it.
