Driveshaft Advice?
the_engineers
66
Lincoln, NE
Wasn't sure where this should go. Please move if there is a better spot.
Looking for a little advice on my van project. The 2WD Allison has a bolted yoke. My center-to-center measurement is 70.88. I've talked to several places and have a couple options...neither of which are perfect.
Option 1: Have a slip-stub driveshaft built. The places who said they can do it are all spec'ing 4 x 0.063 DOM. Max speed would be 90 (seems ok). They still worry about the length, which makes me worry about longevity.
Option 2: Add a carrier bearing. The van has a frame crossmember 22" behind the trans yoke that could serve as a mounting location. My concern is that I don't read great things about carrier bearings either.
Thoughts? Options I haven't considered?
Thanks in advance!
jlawles2
1,066
Danbury, TX
Go for the carrier bearing. It adds one u-joint, but it keeps the rear of the allison happy. i don't think the trans would like the slip yolk putting extra axial force or vibration into the rear clutches.
Mike might have a better answer about the rear of the allison taking those forces.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Don't know all the details, but according to the spicer driveshaft calculator, the max reccomended driveshaft rpm for a 4" x .083(they don't list .063 in 4") with 1410 joints in a slip stub configuration is 2963 RPM's. Figuring for 3.73 gears and 245/75/16 tires puts you at a MAX reccomended speed of only 72 MPH. Sounds to me like they figured for a conventional slip yoke and not a slip stub as the extra weight of the slip stub reduces max rpm's. Based on this info, theres no way I would even consider running a 1 piece shaft.
