Driver's Side Motor Mount
N2BRK
2,071
406
Just trying to clarify that I'm on the right path (I've read tons of posts via search!). I run one Merchant Auto on the driver's side, and 1/2" through bolt the passenger side OEM, and I should not have an issue with vibration but have a very stable platform that allows minimal but needed deflection.
Jes?
Wally
6,031
pass side does not need a bolt unless you do alot of heavy reversing under power.
you will still get some added vibration but it wont be as bad as both mounts being merchant mounts.
i still prefer a new stock mount, a bolt and away you go for DD/street/dual purpose rigs
M.A.M.
429
Ohio
I bolted both sides when I put I new mounts. Vibrations are definitely there..
Sent from my HTCD160LVWPP using Tapatalk
N2BRK
2,071
406
thanks guys. So, MA on driver's and leave the pass alone is my plan.
